v2.4.10 for windows does not login to Smartlink iPhone is fine
Have not used my Surface 2 outside the house in about 9 months using Smartlink (2.4.10)
Cannot login to Smartlink, all i get is a blank white screen that has OK in teh top left corner and a cancel button above that, changed the password, iPhone works fine on local and smartlink
Leaving tomorrow, really don't want to upgrade to 2.76 hours before I leave.
I was under the impression the 2.4.10 was a stable ver in 2.x
Any ideas
"If I recall correctly, a security upgrade at the the SmartlLink registration server now requires that you update your radio to 2.7.6 ( or 3.2.29) in order to use SmartLink."
This is from Al, K0VM.
I had a similar issue and upgrading to 2.7.6 resolved it.
Smartlink server was updated to use the latest version of TLS security (1.3). SMARTSDR had to be updated to match. Won’t work with older versions.
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 305 Shack Infrastructure
- 214 Networking
- 142 Amateur Radio Interests
