CW via SmartLink connected to a remote Flex6400
Best Answers
Hi Grant, Take a look at this group:
RemoteKeyerInterface@groups.io | Topics
They have a simple to build keyer interface and software that will key your rig remotely. Using a Serial port (likely with a USB to RS232 adapter), you close CTS and RTS to ground to key the rig. I think DTR/DSR can be used for PTT, but I don't remember for sure. The RemoteKeyerInterface software detects the control signal changes when you kit the key and sends a "key the rig" command to the Flex over the LAN/WAN connection.
I built the interface this past summer, and it works great. I later coded my own homebrew box (TeensyMaestro) to send the keying commands, so I no longer use the RemoteKeyerInterface, but it is always in my computer bag should my own gizmo stop working.
If you want to send CW remotely using the keyboard instead of a keyer, you can open the CWX interface in SmartSDR and key directly into the CW entry window. With this approach, you won't need the RKI interface or software.
Thanks Len, I'll try the CWX interface first.0
- 398 Community Topics
- 677 The Flea Market
- 190 SmartSDR+
- 195 SmartSDR for Maestro and M models
- 216 DAX
- 391 SmartSDR API
- 87 Aurora
- 331 FLEX-8000 Signature Series
- 987 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 317 Shack Infrastructure
- 222 Networking
- 840 Peripherals & Station Integration
