Getting a Ubiquiti USG (or UDM, UDM-Pro) using VPN to work with SmartSDR (win)
I have Ubiquiti USG with VPN enabled. The VPN works great for everything but the flex (6400). I was wondering if anyone has successfully used their USG/UDM/UDM-Pro with their flex 6000 series radio VIA VPN. If so, what exactly did you do in the controller to get it working.
I understand that SmartSDR uses discovery and has to be on the same subnet as the VPN but this is a little bit outside what I know. Any help would be appreciated.
There are a few reasons I would like to use a VPN instead of SmartLink. Mostly security concerns (close as many doors as possible) and I have other devices (rotor/switch) that I control locally. I also don't want to go out and purchase a RasPi and setup Softether.
Thanks, NT1K
I am pretty sure the USG uses a "L3" routed VPN. The only VPN i know that is pure "L2" ( OSI Layer 2 ) is softethernet and i remember there once has been another bespoke VPN doing layer2 traffice..can´t remember what it was. The Flex needs Layer 2 Network as it uses L2 broadcasting to distinct between direct connection or smartlink need.
Softethernet works perfect with the flex and other networked radios.
Harry
Thanks. I'm aware of Softether but that involves the purchase of a RasPi. I was hoping to take advantage of the hardware I currently own and use. Thank you!
I use the SoftEther VPN with an old laptop. This lets me control my amp, tuner and rotator as well as connecting my TeensyMarstro when I am remote. Although I normally use SmartLink, I can connect SmartSDR to the radio this way.
I am thinking of getting a Raspberry Pi just to experiment with, but I don't need it to run SoftEther.
I have even ran SoftEther on the same computer I always use for the local SmartSDR operation when I'm home.
I now run mine on my Windows PLEX server which is on all the time anyway if it wasn't I would run it on a Raspberry Pi, It would probably even run fine on my Raspberry Pi4 that is running my Node-Red service which is GREAT for station control while running remotely.
good luck
Bret
WX7Y
- 335 Community Topics
- 602 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 400 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 179 FLEX-8000 Signature Series
- 913 Maestro
- 882 Genius Products
- 319 Tuner Genius XL
- 116 Antenna Genius
- 280 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 736 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 950 Third-Party Software
