Balanced input and PTT
On the 6600M is there an internal connection between the Balanced input and PTT?
  • Ted  VE3TRQ
    Ted VE3TRQ Member ✭✭✭
    edited October 2021
    In a word - no. There is a separate PTT RCA input. The balanced mic input is trs.
    Hi Ken, PTT is a separate input. If you have a mic connector that has mic output and PTT together, you will need either need to re-wire your mic cable or build/buy an adapter to separate them.
