White power light
Flex 6400 boots up to solid green power light. After making one transmission, the power light turns solid white. The radio seems to function fine even with the white light but something must be amiss. Looking for ideas. I understand that the white light indicates a factory reset?
    Hi Jim, getting a white light at any time except for explicitly doing a factory reset is definitely not right. Try transmitting low power into a dummy load to see if you still get the behavior. If not, then it is likely RF getting into the radio somewhere.
    If you still get the behavior with a dummy load, then do an actual factory reset (export your profiles first). And see if the behavior continues. If it does, then it is time to submit a helpdesk ticket.
  • Jim
    Jim Member ✭✭
    Thanks Len
