CW Filter width not saved
Erik Carling EI4KF
Member ✭✭✭✭
I use the 100Hz setting for filter width on CW. When I next use SmartSDR on the mode, even on the same band where I was last time, the CW filter starts at 400Hz and I have to change it. How do I retain the 100Hz setting?
Erik EI4KF.
Here's what I did…….
use FRStack. You can create memories that have the frequency plus other things like filter, bandscope with, AF gain, etc etc.
FRStack was great when I installed it and gets better with any update.
OK Pat. I use FRStack anyway so I can include filter in saved memories. It is just that it seems strange that if I depart a band on CW with 100Hz filter, the next time I select that band on CW the filter is at 400Hz.
Yep.... I agree.
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
