FRStack V3.1.32.61Question
I am using a remote Flex-6500 with V3.2.39 SmartSDR, firmware V3.2.39.3374, an Expert 2K-fa and an HF-Auto tuner.
I am new to the program and have a question: It is desirable to disable the TX-1 output when in Tune mode. I have the box checked, but in tune from the UI or from SmartSDR it does not inhibit TX1. Does this feature work?
  • Mark_W3II
    Mark_W3II Member ✭✭✭
    edited September 2021
    I have uploaded build FRStack V3.1.33.62 this evening.
    New features include: Hot keys for Active Slice Select Band, UI Panadapter Create and Close, Hot keys for Panadapter Create and Delete, Rest Radio/Pan for Panadapter Create and Delete
    Make sure you have TX Delay at 150ms
    and in FRStack, Options, PGXL tab, Tune Detect set to Radio Tune Detect
  • John KB4DU
    John KB4DU Member ✭✭✭✭
    FRstack is a wonderful program. I use it a lot. Thanks for the updates and support.
