6400 to MercuryIII Amplifier
WI9Q
Looking for guidance on connecting my 6400 to a new MercuryIII amp. Read the Flex document on amplifier connections, which helped, but was lacking specifics.
Is it straight cables for Key and ALC, or do I need an isolator or other interface? For those running this combo, I would like to hear from you; have you found any operational changes with the Flex?
Thanks in advance for the information.
Yes, straight cables for Key and ALC. But, I don't use ALC. Set TX Delay to at least 10ms and I set Delay for 10ms minimum also.
Thanks, John. Any other setting adjustment for CW or PSK?0
That's all I do for CW. I leave it for SSB but just use PTT. I don't do other modes. 73
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
