RFI ID
Anyone have any ideas what this signal (RFI) is coming from ? It just appeared a few weeks ago. It's on 20 and 40 meters. It sounds like a washing machine swishing back and forth. About 1 second oscillations of low to high pitch.
Have you tried to isolate it to in your house or external to your house?
I have verified this is not coming from my house. Drove the neighborhood with K3 and small magnetic loop to see if I could find it. No luck. There is a neighbor with a new solar installation but that house was quiet.
I also checked with some WebSDR radios that are within 100 miles to me and I don't hear the signal. This is probably local.
The signal is there 24/7. It also changes over time. The pattern changes and the interval will change. As you can see below the signal changing its pattern, spacing and strength.
Probably no fixing it. I have a variety of unknown signals since I live next to an Army post. I set a Remembered TNF on the persistent ones
Video of this "signal" can be seen here. https://youtu.be/sl050wudAm0
charge controller0
- 379 Community Topics
- 636 The Flea Market
- 140 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 271 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
