Flex 6400 ATU
Hello,
Please could someone tell me what power is selected when the ATU button is pressed on the maestro to start the radio tune process?
Kind regards
Richard
  • David Decoons, wo2x
    Answer ✓
    Actually, if running version 2.6.2 or higher under Menu on Maestro there is a TX Band Setting menu. You can set RF and Tune power per band. When you press the Tune button on the Maestro it will use whatever is set for tune power on that band.
    If you hit Tune and radio is transmitting in Tune mode, if you move the power knob it will change tune power and update the TX Band Settings menu.
