Hi Does Some One Have The File For Smart SDR Meter From Wood Box Radio , ,Please Send To ka1wer@hotm
edited February 2020 in FLEX-6000 Signature Series
Hi Does Some One Have The File For Smart SDR Meter From Wood Box Radio , AS There Web Site Is No More , Or Has Been Down For At Least 3 WEEKS ,Please Send To ka1wer@hotmail.com Thank You Very Much , Paul 73s
Welcome!
  • Member
    edited January 2019
    I would also like a copy as well.
  • Member ✭✭
    Just go to woodboxradio.com and find the app and download and install it. His site gives details
  • Member ✭✭
    edited September 2017
    I sent it to you as a zip file as downloaded. No idea what happened to their website.
  • Member ✭✭
    edited March 2019
    I will send it to your email
  • Member ✭✭✭
    edited July 2017
    Here is a Link to my Public Dropbox with SmartSDR S-Meter V1.6
    http://bit.ly/2n9EoT2
  • Member ✭✭
    edited March 2019
    Howard Dropbox does not like The transfer. Send email to KC9RF@arrl.net
  • Member
    edited March 2017
    Howard,
    I have an older version of SmartSDR S-Meter...
    Would u kindly forward ur newer version please.
    wb3fsr@comcast.net or shoretrain@gmail.com
    Tnx
    PeterV WB3FSR Jersey Shore
  • Member ✭✭
    edited August 2017
    do you have smart smeter V1.6 ?
  • Member ✭✭
    edited August 2017
    send me this file to va2jn@outlook.com
  • Member ✭✭
    edited November 2017
    Can Ross, Bob, or Howard please send me the meter file.  I did not know that it was available.  Much appreciated.  My email is robert_paluf@hotmail.com  Or post on Dropbox if that is easier to share.
    Bob, KV4JO
  • Member ✭✭
    i have version 1.0 the name is Smart smeter plus but i dont have v1.6 if you have please send me zip file at va2jn@outllok.com
    73'
  • Member ✭✭✭
    AFIK - SMART SMETER PLUS IS 1.6 even though it reads V1.0
    Try this link
    https://www.dropbox.com/s/223si9ks962n1av/Smart%20S-meter_V1.6.zip?dl=0
  • Member ✭✭
    edited August 2017
    No problem with a download of this file.  Thanks Howard!
  • Member ✭✭✭
    Sorry to re-open this thread... while I have set the CAT port to point to my Slice A, and the Smart S-meter follows the frequency displayed there on Slice A, I don't yet see how to get DAX audio into the program. How, exactly, is audio routed into the program? Not through CAT, surely??
  • Member, Super Elmer Moderator
    Hi John, I don't think audio goes to the S-Meter program. I suspect that it uses the API to read meter info and display it. I am away from my radio at the moment, so I can't confirm that yet.
    I will post back if I can figure it out.
    Hi John, I found the likely way the S-Meter works. There is a CAT command to read the S-Meter from the radio:
    ZZSM Read the S-Meter
    I have been doing all my homebrew stuff using the API, so that is how I tend to think...
    In any event, it looks like all the info that the meter uses comes from CAT, not DAX or the API.
  • Member ✭✭✭
    Thank you for that insight Len! I'm guessing I just wasn't on a frequency with enough audio to move the meter. My noise floor seems to be about zero since I put up a new T3FD antenna from DipolesUSA (dot) com. I'll try it again. Since my frequency is tracked then I would expect the CAT command to read the S-Meter to also be working.
    I agree... I would expect the same thing. One thing you can do to verify that it is working is to look at the S-Meter in SmartSDR and see if the WoodBox S-Meter tracks it. If there are no strong signals around, you can even use the AM broadcast band to get a nice strong, steady carrier to compare with.
  • Member ✭✭✭
    John,
    Best to set up a unique CAT com port for the S-meter, besure to start it ;) Here is an example of the meter in action on my YouTube replay of last Sunday's Flex Net on 14.329
    Dudley
    WA5QPZ
  • Member ✭✭✭
    A good source for the meter app is http://www.craigwilliams.com in the Flex Radio section. Good down load for 6000 series and even for Power SDR. Just did the down load and set up CAT and it worked.
