Intermittent No TX Audio when running SmartSDR
Mike - ZL1MRC
Hi, not too sure if anyone else as seen this, however in the latest release of SmartSRD I intermittently get no TX Audio when keying the radio. It can happen at anytime durning a QSO, however is so intermittent I not too sure where to go from here.
Has anyone else seen such a fault?
I have my key connected directly to the Radio and use ProAudio for the MIC input. I am running on a MAC under Parallels with the latest copy of Windows 10 will all updates applied. I can't see that been the problem as its when I directly key the radio from the Key.
I also run digital modes (JT65, RTTY, PSK etc) and have never seen the problem with that. Its only when the radio is directly keyed.
Thanks and 73,
Mike.
Thanks and 73,
Mike.
Had not reply, so I have raised a support ticket.
Are you still on here Mike ? Old thread but i see this issue also. It can happen 1 of 3 times and sometimes 1 of 6 times. Did you get the issue resolved. Running latest software July 2021. 73 de LA4XLA0
- 391 Community Topics
- 665 The Flea Market
- 166 SmartSDR+
- 446 SmartSDR for Mac
- 208 DAX
- 387 SmartSDR API
- 65 Aurora
- 304 FLEX-8000 Signature Series
- 978 Maestro
- 868 FLEX Series (Legacy) Radios
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 826 Peripherals & Station Integration
- 145 Amateur Radio Interests
