Tuner Genius Low Pwr Warning
Are you trying to tune at 40 watts? Recommended tuning wattage is 20 watts.
Usinf a Flex 6000 series go into TX band settings and set each band tune value to 20 watts.
There is a firmware issue with some non-Flex transceivers. I have the ICOM 7610 and got the low power warning up to 100 watts and then high power above that. A firmware fix is being done (I have Beta tested it) and it will resolve this issue. This appears in non Flex transceivers. You didn't state whether you were using a Flex transceiver on FT8.
[{"insert":"Wayne\nThanks for replying. I’m using a Flex 6700. The issue seems to be happening on my 6m Yagi, which is already resonated for 1.2 without tuning. I’m not sure if that’s a factor. I’m not setting the tuner in Bypass when using those frequencies.\n"}]0
[{"insert":"Dave\nim using SmartSDR v3.2.39 and in the TX settings Tune Pwr is set to to 10 watts Max. I think it may be that my 6m Yagi is already resonant on 50.313 which would negate any tuning but I never transmit more than 50 watts anyway on that band -antenna is rated for 300 watts. Not understanding why power needs to be lowered for ft8 at 30-40 watts… Using a Flex 6700\nSloan N3UPS \n"}]0
Try setting TUNE power in TX Band Settings window to 20 watts for all bands 160 through 6. 10 watts is too low.
If your antenna is resonant on 6 meters you can enter the segment of the band where you want to bypass the tuner. For example if it is resonant from 52.000 to 53.000 then in the band configurator window of tuner setup check the box to bypass and enter 52000 for start and 53000 for end. Notice they are entered in kHz and not MHz.
I see the low power warning too. I have both an ICOM 7610 and 7851. I got a beta version of the FW last week. Now the 7610 tunes just fine, but the 7851 still errors out with low power. Their is a latency issue, while tuning the 7851 power will drop briefly to protect the radio, at a point when the TGXL hits a very high SWR briefly. They are working on another FW version with a bit longer latency which will correct the problem with my IC 7851.
I guess the 7610 must be slower at cutting power than the 7851. I try and tune around 20 watts but of course with high SWR the TGXL sees less power briefly and errors out.
The good news is once tuned the performance of the TGXL is quite impressive, speed, accuracy all superb.
I look forward to the next FW release and hope its soon.
Peter
W2PP
- 376 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
