Gothic Diadect Font
I am installing 3.2.39 on my FD laptop and now the VFO freq on the flag is cutoff on the top. I tried to install the font but so far noting is working. Where should the font be installed?
I'm glad you posted this...I have been dealing with the issue for some time. I made sure both fonts are downloaded and installed. I continue to have the VHO freq top cut off...see the attached pic...
73, Ronald
Here's a link to a description of how to install fonts on Windows 10 PC's
Thanks for the information Don...I checked again to make sure but I have downloaded and installed the fonts as described in the Windows 10 information you provided. The only issue I'm having is in the side information display. As shown in the earlier image the top of the numbers are cut...no big deal...just would like to know why.
Thanks again
73, Ronald, W4RJF
Hi Ronald... good to hear the font got installed ok. The stuff you're seeing at the top of the letters could also be due to a mismatch between your display driver and the resolution of the screen. I've seen it happen before on certain types of monitors, if there's not an EXACT match (or overlap) between the screen resolution and the display size selected in the Control Panel/Display
- 379 Community Topics
- 631 The Flea Market
- 120 SmartSDR+
- 193 DAX
- 38 Aurora
- 947 Maestro
- 924 Genius Products
