Setup my FLEX6400 and de BLA350Plus. Please help.
Hi members, I recently got the BLA350Plus,
My question is: Does anyone have experience with setting up the FLEX 6400, for example the Radio set up menu. My hardware configuration seems correct to me. Are there any adjustments needed in the Radio Setup Menu or with the BLA350?
BLA350 : the setting on the LED screen is : Operate Auto
FLEX 6400: The setting has not yet been changed.
TUNE: at 10 Watts With the FLEX I can make 10 Watts, but the BLA350 remains inactive and gives no error message.
Think I have set something wrong because the BLA350 does not activate via the PTT.
Please help.
Cees, PA3CVI
Hi Cees, You need to connect TX1, TX2 or TX3 to the PTT jack on the amplifier. Then in Settings, TX Band Settings, make sure that the appropriate RCA jack is selected for the bands you want.
In this example, my amplifier PTT is connected to TX1, I have TX2 selected for a different piece of gear that I no longer have.
The PTT jack on the 6400 goes to a mic PTT switch or to a foot switch to put the radio into transmit.
Tks Len,
I checked the TX band settings for my band segments, as you left them, unfortunately without result. you advised: " You need to connect TX1, TX2 or TX3 to the PTT jack on the amplifier", but the BLA350 has no assignment to a TX setup .
Are the settings in Radio/Setup still important? I Haven't mentioned that I'm transmitting in CW mode, maybe that has an influence?
Len, if you think that regarding the FLEX, all the settings are correct, then the BLA350 setup would not be correct?
Regards,
Cees, PA3CVI
Hi Cees, I think the problem is that in your diagram, you show connecting the BLA350 PTT to the Flex PTT. It needs to be BLA350 PTT to Flex TX1. Then make sure that the RCA TX1 box is checked for each band that you want to use the BLA350 on.
I also see that you have the TX Profile set to SO2R_TX1, but I would think Default is more in line with your setup.
Oh, would that be the solution.
I had already measured what came out of the PTT Out and that was 3.3 Volt, both the Flex in TUNE-in and out. Can therefore never address the amplifier. Be sure to try it later, you'll hear from me. Thanks for your help.
Regards,
Cees.
Regards,
Cees.
What a relief Len, it actually works. I am still of the old generation, and in those days the internet didn't even exist. How nice it is that such forums exist and you can ask questions to fellow amateurs regardless of where they live. There is always someone who wants to help you, thanks for your help Len.
Kind regards en 73,
Cees, PA3CVI
That is great news Cees! I am glad you got it working.
Cees,
I have the BLA350 plus and am using it with a flex 6400 and mfj 993b tuner. I have had trouble with overdriving the amp when I try to use 10 watts. The amp goes into protection mode and has to sit powered off for like 5 minutes before it works again. I would be curious if you have success using 10 watts of drive power?
Thanks!
Mitch
KE0UAS
Mitch I've only had the BLA350 in operation for a short time. Annoying for you. So far, no problem with that. Cees
Cees,
Glad to hear you aren’t having trouble. I haven’t had the amplifier for very long. I’m still learning as well. When I’ve had trouble is in voice mode (SSB). I think voice peaks probably cause the overdrive shutdown because it is fine when I test it with tune button. Have you tried the amp yet for voice modes?
im happy to know someone else is using this amp.
mitch
ke0uas
Well Mitch,
in the thirty years that I h've been a licensed radio amateur, I never have held a microphone in my hand. Always worked in CW mode.
However, I can imagine that in Phone mode you will peak above the maximum HF output.
73, Cees, PA3CVI.
Cees,
Never too late to try something new, ha! Thanks for the info. I hope the Rmitaly works well for you with CW!
mitch
ke0uas
Dear Mitch,
I don't know if you regularly read the post, but I'll try to ask my question anyway, hoping you're QRV.
I have a problem with the BLA amplifier.
Whenever I go on transmit, the BLA cuts out because there is too large a SWR.
Occasionally it goes well after I have restored the BLA and then tuned it, I think I have found it, but if I turn the BLA completely off and then on again, the BLA says that the SWR is again too high. If I follow the same setup again, it doesn't help.
I just can't figure out what the error is.
If I put the BLA in Standby mode and tune with the FLEX then I have a very low SWR. If I am going to transmit with 100 Watt then I have no problem.
The BLA in Operate Mode immediately gives an error message even if the FLEX gives an input HF of 2 Watts.
What is your experience with this ?
73, Cees
Have you tried using a different transceiver with the amplifier? I am speculating that it is not a Flex problem.
No Eric, it seems unlikely to me that the FLEX is the cause. I try to rule out as many causes as possible to determine the cause.
Cees,
what are you using for a tuner? I’m using an mfj 993B auto tuner. From my limited experience with the amp, I’ve found that it does seem to be pretty sensitive to SWR. I set the tune threshold on the mfj to 1.5 SWR which is the lowest setting. To tune I put the tuner in auto mode and the amp in standby. Then I tune with 25-30 watts from the flex, using the flex’s tune button. I initially tried tuning with 9 -10 watts and had similar trouble to you. Tuning with 25-30 watts worked better. Once tune is complete I switch amp to operate and transmit with 9 watts. Hope this helps. Let me know what you find out. This amp is pretty new to me too.
Mitch
KE0UAS
Mitch, I have the same swr/pwr atu. I will follow your proposal. I will also check to see if there is a ground loop. I'll definitely let you hear from me. 73 Cees
Hi Mitch,
I didn't realize the MJF was so sensitive to the power where you have to adjust it, I really hadn't thought of that.
That also explains the failure of the experiments I've done, such as disconnecting the printer USB connection, not grounding the MJF. Sometimes it worked and sometimes it didn't. Now understand that everything depends on the correct MJF adjustment.
I do think that the MJF is very sensitive to the correct adjustment, I wondered whether that could be improved, for example further away from the PA, ferrite decoupling rods and the like.
Don't get me started too soon, but so far everything is going according to plan and I can usually make about 250 Watts. Thanks for your help.
As soon as there are further progress or comments I will let you know.
Regards and 73, Cees, PA3CVI
Cees,
Thanks for the update,
I'm glad to hear you are having success so far. This community is great, really like being able to find people with similar and equipment and questions to help work problems out.
I initially tried tuning with 10 watts thinking I could use the same power to tune as I would use for driving the amp. I wasn’t getting good tunes. The amp would still lock down for high SWR. Seemed to work much better when I used higher power (25 watts) for tuning. The MFJ manual isn’t real clear on this, but I agree that the tuner may be able to be improved.
please keep me in the loop on your experience with the amp and tuner. You are the only one I know of besides myself that has this set up.
Thanks!
Mitch
KE0UAS
-1 -
Hi all
Need some help please! I have a 6400 M
I have my RM BLA 350 set up as in the photo by Cees above except the PTT on the amp is connected to TX1 on the radio. The box is checked. The Amp is off and the tuner is off. When I turn the radio on to a busy band, the band shows nothing in the Panadapter as if the band is dead which I know it isn't. When I return the antenna directly to the 6400 M everything normal, busy band again. What am I doing wrong. Shouldn't I be getting signals on the band even tho the amp and tuner are off? I am really shy about turning the amp on. It is very possible that I am mis-thinking what should be happening with everything off except the radio.
Thank you
Bob W1AGC
I've a FlexRadio 6600M, Maestro B, BLA350+ and MFJ-993B ATU. The ATU must be turned on. In some ATUs, if the power is off then no RF passthrough.
1) Footswitch into 6600M PTT RCA. MultiFlex set to Maestro.
2) RCA cable from TX1 to BLA350 PTT (bottom jack).
3) Make sure the TX Band Settings has TX1 enabled for every band you desire to use the amp on.
4) Also, best to set the RF PWR setting to the same increment so when you power it on again it will default to that setting. Mine is set at 10.
5) Power on BLA350 into STANDBY on the display.
6) Set FlexRadio TUNE for 15 watts.
7) Press TUNE button on FlexRadio then Tune on ATU. Make sure SWR is below 2:1 or the BLA350 will trigger input overload protection.
8) Then set FlexRadio to a quiet frequency on any band in FM mode and adjust output to 9-12 watts using the ATU.
9) After all that. Make sure BLA350 Low-Pass Filter switch is set to AUTO.
10) ⇒ No ALC connection is necessary ⇐. Just make sure that the FlexRadio output is below 12 watts.
11) You can use ALC. So then you'll lower the potentiometer on the back of the BLA250 to zero (full counterclockwise facing the back).
11a) In the FlexRadio TX Band Settings set for HWALC on all the bands desired to use the BLA350.
11b) Set the BLA350 display for ALC ENABLED so the wattage is showing.
11c) Then crank up the FlexRadio to RF PWR to full output again in FM mode.
11d) Key-up and slowing adjust the ALC potentiometer on the back of the BLA350 until the display on the front shows 10 watts. That's it!
12) Then on the BLA350, flip the switch so the display says OPERATE. Key up and BLA350 should show some output.0
- 363 Community Topics
- 624 The Flea Market
- 8.1K Software
- 68 SmartSDR+
- 181 SmartSDR for Maestro and M models
- 420 SmartSDR for Mac
- 270 SmartSDR for iOS
- 253 SmartSDR CAT
- 188 DAX
- 379 SmartSDR API
- 30 Aurora
- 233 FLEX-8000 Signature Series
- 930 Maestro
- 908 Genius Products
- 328 Tuner Genius XL
- 120 Antenna Genius
- 291 Shack Infrastructure
- 204 Networking
- 447 Remote Operation (SmartLink)
- 771 Peripherals & Station Integration
- 989 Third-Party Software
