Gothic Diadect Font
I am installing 3.2.39 on my FD laptop and now the VFO freq on the flag is cutoff on the top. I tried to install the font but so far noting is working. Where should the font be installed?
  • RFord
    RFord Member ✭✭✭
    I'm glad you posted this...I have been dealing with the issue for some time. I made sure both fonts are downloaded and installed. I continue to have the VHO freq top cut off...see the attached pic...
    73, Ronald
  • VE7ATJ_Don
    VE7ATJ_Don Member ✭✭✭✭
    Here's a link to a description of how to install fonts on Windows 10 PC's
    How to Install Fonts in Windows 10 | Digital Trends
  • RFord
    RFord Member ✭✭✭
    Thanks for the information Don...I checked again to make sure but I have downloaded and installed the fonts as described in the Windows 10 information you provided. The only issue I'm having is in the side information display. As shown in the earlier image the top of the numbers are cut...no big deal...just would like to know why.
    Thanks again
    73, Ronald, W4RJF
  • VE7ATJ_Don
    Hi Ronald... good to hear the font got installed ok. The stuff you're seeing at the top of the letters could also be due to a mismatch between your display driver and the resolution of the screen. I've seen it happen before on certain types of monitors, if there's not an EXACT match (or overlap) between the screen resolution and the display size selected in the Control Panel/Display
