CW and VOX problem - Flex 6500 V. 2.6.1
while in CW mode the vox is activated
Is it an error already detected?
setup Flex 6500 - V. 2.6.1
73s
Javi LU5FF
I queried this last month, nobody acknowledged it though. I reckon it’s a proper bug. To work around, go into DIGU or DIGL and switch off VOX it’ll then hold when you go back to CW.0
OK my friend
but in my case it is not possible to distil the vox
Even if I'm in CW and picks up some sound the mic activates the TX
does not send sound but cuts reception
That's why I think it's a problem to solve
73s
Javi LU5FF0 -
Quería consultar nuevamente a los medios de comunicación.
Si este es un problema ya detectado o tiene que tener un ticket?
Puede que tenga que restaurar mi equipo desde cero,
la verdad de que la voz está activada mientras uno está haciendo cw es muy molesto
Gracias
Javi LU5FF0 -
I have exactly the same problem. And the problem is when in CW mode the VOX indicator the "faded blue"; not "gray". if there is any noise in the shack that would trigger the VOX (if in SSB mode), it disrupts any received signal. So if you are listening to CW and cough or otherwise make a noise, you lose parts of the CW signal -- making it impossible to copy.
I have tried resetting the radio (Flex6700) which is running Version 3.1.12.51 but nothing seems to work. The only way I can stop this is to physically disconnect the microphone while working CW.
Bill K5WAF0 -
@Javi LU5FF you should upgrade to SmartSDR v2.6.2. The version of SmartSDR you are using has some issues fixed in v2.6.2 that will improve the stability of your radio.
You may need to reset the persistence database to prevent this radio state from being recalled using the HelpDesk article How to Reset the Persistence Database for a FLEX-6000
Has there been any fix to this problem?
Bill K5WAF0 -
I have to say a big thank you to the community system... does what it says on the tin.
Firstly, from above, resetting the VOX in DIGU seems to work, whereas going into USB/LSB does not carry over when going back to CW. Thanks GM7VSB
Secondly, Tim's suggestion to reset the persistence database makes the problem go away... follow the instructions carefully.
Great work Flexers all...
73 de Jim
g3yla
Flex6500 v2.7.6
2
- 113 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
