Flex 6600M and Writelog.
Will W/L log the QSO frequency from each radio?
See my current SO2R setup @ QRZ.Com.
Thanks for reading, Mike, WM5DX.
Hi Mike,
It should work. I tested a 6700 for WL SO2R two years ago and made a write up on this forum. I beleive it is a Flex documnt as well.
However, you might be forced to use the PC SmartSDR version. If I recall correctly WL will assign slice A +B for radio A and slice C+D for radio B. This cannot be accomplished in the Maestro.
Hi Mike, I found these two documents essential in getting Writelog to work SO2R with my Flex 6600.
WriteLog’s FlexRadio Rig Driver (1 of 4)
<https://writelog.com/writelogs-flexradio-rig-driver>
and
How to Integrate Writelog for SO2R with FLEX-6700
I got it working for SO2R, and did a couple contests, but it is incompatible with my remote setup, so I don't SO2R very often. I don't have a Maestro, I use SSDR on Windows PC.
Mark K6UFO
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
