FRStack3 how to set up TX mode&band hotkeys for stream deck
I would like to know this as well. I have programmed keys to change band e.g 50.313 and I have programmed keys to change mode e.g DIGU. But in Stream Deck is it possible to have a key programmed that does both - so press it and band and mode both change? A mutiple action. If anyone knows how, I would be grateful for details. Thanks de Erik.
You could just program a key as a memory like I have done. You need to have the memory set up in Stacks then program the stream deck key.
GET URL http://localhost:13522/api/activeslice/memory
param= "your memory . . . one of mine is 3.690 so param=3.690"
In Stacks3 you can set mode, frequency, nb,volume,etc for that memory.
That is true. A good idea. Thank you!
Add the Multi-action to your Stream Deck Page. Then, drag over the actions you want.
Also, drag over the "delay", if you want to run the multi actions with a delay between each.
Alan WA9WUD
Excellent, that was really what I was looking for. Thank you.
I have done it Alan, thanks again.
Is there a way to perform multi-actions associated to 1 hotkey when using a windows keyboard as the hot key?
Does this video help? https://www.youtube.com/watch?v=1MLi--03l2M
I do not know if it will as I'm a beginner and you may have seen it anyway.
- 113 SmartSDR+
- 944 Maestro
