JS8CALL
Has anyone managed to get JS8CALL to work with their 6400?
I put in the IP of the radio and the same port as I use WSJT-X (192.168.1.253:5002) but the baud rate, etc stays grey and, as you can see, I have no CAT control. Anyone help?
Hi Cy, I haven't played with this very much, but I did get it to connect using CAT. I had to set the rig to Kenwood TS2000 and select a CAT com port that I had set up for something else. I have not read up on it yet, so I did not get anything to decode. Not sure I am even listening to the right signals...
I (fortunately) set my RF Power to zero so that I would not inadvertently transmit, and that was a good thing. Not sure what I did, but the rig keeps going into transmit... I will actually read the documentation later today and may get this working. If I figure it out, I will let you know what I did.
Great tip! I got it working.
Here is what to do:
TS2000 with your com port
Whatever your PTT is
and now.....TURN ON THE DAX ON YOUR MICROPHONE
PRESTO!
Excellent!! I am glad that worked Cy. I have seen other posts about using the FlexRadio 6xxx interface and 127.0.0.1:5002 address to CAT, but I did not get that working. At some point in fooling around with this, the VOX got turned on. Once I turned that off, the random transmitting stopped.
Cy,
I think the issue you had with the TCP port connection is you should use the "localhost" or IP address of the computer, not the radio .. SmartCAT makes the connection to the radio (you need SmartCAT and DAX running for connection to the radio .. I have the radio and the computer that I run SmartSDR on, both with reserve IP addresses by MAC addresses in my local router..
Dudley / WA5QPZ
OK Cy, I got it figured out...
First I had to add a TCP port. When I clicked the add button, it came up with 60000, so I just left it.
Next, I changed the rig to the FlexRadio 6xxx and changed the network server to 127.0.0.1:60000 to use the port I just created. 127.0.0.1 is the local host that Dudley mentioned, above, and is the universal way to set this up. Dudley is also correct in saying that you can use the IP address of your computer (I tried it just to be sure). I recommend the 127 address in this application. Now you have a true Flex connection instead of a Kenwood comport connection.
Hey Dudley, I heard you in there on 20 yesterday and tried to answer, but by the time I figured out how to set up my transmit signal properly, you were gone. I was overdriving the input, and figured out that I needed to cut the DAX TX gain back a bit.
In any event, your SNR was +3 dB. Definitely one of the stronger signals on the air!
@Cy Stanway Thanks for asking the question Cy, I never would have tried this without your inquiry!
Hi Len,
That was my usual antenna at about 30 watts out.. Nice and thanks for the report, I had moved my frequency to 1300 Hz offset, so you were pretty darn close, just playing around, I will have to pay more attention on JS8 , really don't know much about it just making sure I can make it work . 😁
- 390 Community Topics
- 659 The Flea Market
- 53 Aurora
- 971 Maestro
- 945 Genius Products
- 307 Shack Infrastructure
