How does Flex 6700 manage 165Mhz RX
Amos Sobel
Hi
Flex 6700 does receive up to 165MHz using 2x ADC of 123Ms/Sec. This can't be direct sampling. Is there a Transverter inside or some special trick using 2x ADC's?
Amos 4X4MF
The sample rate you quote is that of a 6300/6400.
The 6700 has 2x 245.76 msps ADCs.
Your citation is not relevant to your original question.
Have a nice day.
I guess they are using harmonic sampling... As the spectrum folds around fs, one can use the 2:d Nyquist zone between fs/2 and fs with proper frontend filtering. All depending on the analog part of the A/D
We use multiple Nyquist zones. See the response from Steve N5AC in this community post.
https://community.flexradio.com/discussion/6609839/how-about-covering-monitoring-fm-aero-bands
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
