How does Flex 6700 manage 165Mhz RX
Amos Sobel
Hi
Flex 6700 does receive up to 165MHz using 2x ADC of 123Ms/Sec. This can't be direct sampling. Is there a Transverter inside or some special trick using 2x ADC's?
Amos 4X4MF
The sample rate you quote is that of a 6300/6400.
The 6700 has 2x 245.76 msps ADCs.
Your citation is not relevant to your original question.
Have a nice day.
I guess they are using harmonic sampling... As the spectrum folds around fs, one can use the 2:d Nyquist zone between fs/2 and fs with proper frontend filtering. All depending on the analog part of the A/D
We use multiple Nyquist zones. See the response from Steve N5AC in this community post.
https://community.flexradio.com/discussion/6609839/how-about-covering-monitoring-fm-aero-bands
- 632 The Flea Market
- 127 SmartSDR+
- 195 DAX
- 40 Aurora
- 955 Maestro
- 927 Genius Products
- 338 Tuner Genius XL
