PGXL T/R Relays
When using the PGXL on 160-10 meters there is a very slight click when going from Rx to TX but on 6 meters it sounds like someone tripped over a pile of tin cans... is this normal? If so why?
No, not normal. I have the same click sound going from RX to TX on any band.
I do have a separate issue. When making a 15 second transmission at 1 KW on FT8, I hear a click every couple of seconds once the temperature reaches 60C. Then a couple of clicks when the fan cools the amp down. I interpret this to be thermal expansion and contraction of some part of the amplifier. This is after the 3rd month of usage. Never recall hearing it the first 2 months. When idle or standby, no clicks.
TNX.. ill send in a ticket....... the amp on 6 meters is very different than on any other band.. heats up almost instantly and has low output... If I turn up mu 6700 to full output I get about 900 from the amp but the fans drive me out of the room...VERY noisy
With 50 watts out of my 6600, I easily get 1200 out of PGXL on 6 meters.
With 60 watts out of my 6600, I get 1500 out of the PGXL on 6 meters.
For FT8, I usually keep it around 800 watts on 6 meters.
Mine is 3 months old. When did you get yours?
Nice to work you on 6m. yesterday!
73, Bill
I have had it about a month now
- 335 Community Topics
- 602 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 400 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 178 FLEX-8000 Signature Series
- 913 Maestro
- 882 Genius Products
- 319 Tuner Genius XL
- 116 Antenna Genius
- 280 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 736 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 950 Third-Party Software
