Storing Spot Colors
K2MO
in SmartSDR API
All:
How does one store DX Spot text and background colors? I have a Flex 6600M and I've noticed that the colors revert back to default when I restart the rig.
This doesn't happen when using SmartSDR. It only occurs when using the 6600M stand alone. I'm also using Slice Master.
Any ideas?
Tony
Tony:
I don’t have a built in “M” but have a similar setup; 6400 and Maestro. My understanding is the display on the “M” is basically a Maestro.
There is a “spot” setting configuration menu on my Maestro. Maybe there is one on the “M” display as well? Look for it and adjust to suit
GL.
Pat W5WTH
Pat:
Yes the M series lets you access spot settings via the menu. The problem is that the colors revert back to default when you restart the rig.
Tony
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
