Storing Spot Colors
K2MO
K2MO Member ✭✭
All:
How does one store DX Spot text and background colors? I have a Flex 6600M and I've noticed that the colors revert back to default when I restart the rig.
This doesn't happen when using SmartSDR. It only occurs when using the 6600M stand alone. I'm also using Slice Master.
Any ideas?
Tony
  • Pat_W5WTH
    Pat_W5WTH Member ✭✭
    Tony:
    I don’t have a built in “M” but have a similar setup; 6400 and Maestro. My understanding is the display on the “M” is basically a Maestro.
    There is a “spot” setting configuration menu on my Maestro. Maybe there is one on the “M” display as well? Look for it and adjust to suit
    GL.
    Pat W5WTH
  • K2MO
    K2MO Member ✭✭
    Pat:
    Yes the M series lets you access spot settings via the menu. The problem is that the colors revert back to default when you restart the rig.
    Tony
