CW Too Fast
Anyone else notice that, after upgrading the s/w, the keying is slightly off? The dits don't wait until the dahs are finished and throw in a premature dit! Am I crazy or is this real?
Hi Cy, are you using mode B iambic keying, but expecting mode A? Try changing to mode A and see if that makes a difference.
Hi Len
I tried. Same issue.
c
In that case, you might try exporting your profiles and do a factory reset. One of the recent posts has the full procedure. I am currently using my own homebrew keyer, but I will plug my key into the radio and see if I can recreate your issue. If a reset does not work, you should probably submit a help desk ticket.
EDIT: I just tried the keyer in my 6400 and it works great. A and B modes operate properly. A straight key connected to the 15 pin accessory connector also behaves itself.
Hey Cy, any progress on the CW keying issue?
No. There is a little glitch in the software and so it’s gone back to the developers. I cannot use an external care because the excess report is occupied. And that is how the keyer is supposed to hook into the radio unless I’m missing something
Hi Cy, Can you edit this sentence? I think spell checker got you...
Hi Cy, I may be misunderstanding your set up...
How are you connected?
- Paddles to the key jack
- Paddles to an external keyer, the output of which connects to the key jack
- Paddles to an external keyer, the output of which connects to the accessory jack
You mention software going back to the developers, what software (SmartSDR, N1MM, K1EL WinKeyer, etc)?
LOL
I can't use the external keyer because the accessory port is being used by my linear to interface the 6400 with it.
Can I use the output of an external keyer to the key jack on the 6400?
I am connected directly to the key jack in the 6400
Cy
You can connect a keyer to the key jack. Just turn Iambic off, that is what I do.
That's it? I can try that. Any tips on the wiring?
c
That's it! I wired my connection per section 7.4 of the Hardware Reference Manual. Use a TRS (i.e. 1/8 inch stereo) plug. Connect ground to the sleeve and "hot" to the tip. Leave the ring unconnected.
Thanks. Doesn't get much easier than that!
c
Yep, very easy! I see in my log that we worked each other during Field Day last summer on 40 CW. Small world...
Cy, you aren't going crazy. I just received my new 6600 and noticed something odd about the keying. The timing appears to be off somewhat, such that sometimes a string of dits appear to speed up and characters slightly truncated. Not all the time .. but noticeable when it occurs.
Daniel - W7NGA
Hi Daniel, what version of the software are you running? The latest, 3.2.34, was supposed to fix the CW timing issues. If you are running 3.2.34 and are having CW timing problems, I would suggest sending in a help desk ticket so that Flex can investigate further. If you are on an earlier version of 3, then you might want to upgrade to the latest to see if it cures the problem.
If you upgrade, read the release instructions very carefully, there are some profile corruption issues that you want to avoid.
I have been playing with my own homebrew keyer lately (part of my TeensyMaestro), so I don't see any CW timing issues. I will have to plug my paddles into my 6400 to see if I can spot any timing problems.
Just fooling around with it tonight, the CW timing seems perfect. No truncations, no speedups, no slowdowns.
So far, it acts the same whether actually keying the rig, or just listening to the sidetone. I have not done rigorous testing, but so far so good. I am on version 3.2.34 using a 6400.
Running 3.2.34
CW seemed perfect two days ago, and I have left the 6600 running since then. Only today did I notice a timing oddity. Perhaps it is associated with a memory leak. I will try to investigate further and see if I can better pinpoint the problem. I am using SmartSDR for Mac, and will see if I can duplicate the issue with the Windows version.
I have powered down and will see if the issue exists after reset.
Apple Mac mini M1, direct ethernet connection.
Edit: As an electronics engineer I should do a better job at categorizing the problem. I have not, as yet, looked at the RF waveforms to see if the issue exists at the ANT output or perhaps is an anomaly that extends no further than the sidetone.
Rebooted ... running for 2 days and CW operation via QSK and Break-in appears to be working correctly without any issues.
I have to throttle back to 66 wpm so there might be issues at higher speeds. My ear fails me at anything higher than that! 🤪
Just kidding!
Daniel - W7NGA Seaside, Oregon
I upgraded to 3.2.34 a couple of weeks ago and noticed this issue, it throws you a bit when you hear it but not sure if it actually affected the keying/RF - at least I had no complaints about the keying etc., did a cold reboot and seems to have fixed it, for how long we shall see.
Mike - GM0DYU.
OK, lasted a couple of days, on CW this morning and the problem is back, odd timing issue with the internal keyer, seems to make shortened dots/dashes intermittently, will reboot again I guess see if it clears up once more, anyone know if this is a known issue which Flex are working on?
Hi Mike, have you tried a factory reset? If not, export your profiles first, then try the reset followed by a profile import. If that does not fix it, submit a helpdesk ticket so that a Flex engineer can look into it.
- 318 Community Topics
- 575 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 157 SmartSDR for Maestro and M models
- 386 SmartSDR for Mac
- 251 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 356 SmartSDR API
- 9K Radios and Accessories
- 123 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 848 Genius Products
- 437 Power Genius XL Amplifier
- 298 Tuner Genius XL
- 103 Antenna Genius
- 268 Shack Infrastructure
- 189 Networking
- 132 Contesting
- 698 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 923 Third-Party Software
