WSJT-X defaulting to LSB on all bands
In WSJT-X radio setting tab make sure you select Digital/pkt mode.
Also what do you have selected for radio in that tab?
[{"insert":"Hi Dave,\nYes, the software is set for Digital/pkt mode. The radio is Kenwood TS 2000. These have been the settings for the last 4 years on the software with my FLEX Signature radios. I was thinking, when I get home, to try the USB setting and see what happens. When I am using HRD or FLDIGI with the FLEX 6400, I am not experiencing this problem. Of course, once the radio switches to LSB on TX, it will not switch back. First time I have ever seen this.\nThanks for getting back to me so quickly.\n\n73\nMark\nKK2L\n"}]0
What other software are you running besides Flex SmartSDR and WSJT-X? Most times it is always caused by a software program telling the radio to change modes.
If you like, contact me via email and I can send my number. I can assist via TeamViewer if you like. My email is good on QRZ.
Instead of Kenwood TS2000, try creating a CAT TCP port 5004. Then open WSJT-X and go to settings/radio tab. Set radio to Flex 6xxx. Set IP address to 127.0.0.1:5004
Hi Dave,
The computer is dedicated to the FLEX. The only other software I am running with WSJT-x is my logging software (N3FJP) and the Chrome Browser As I mentioned prior, I have made thousands of contacts using this configuration without any issues. I have made no changes to the computer recently. I like your idea of a new CAT port. I am at work now but where do I insert that new IP address (SmartSDR or WSJT-x)?0 -
Mark
As per our email, I will talk to you on the phone tonight. You first create a new TCP CAT port 5004, then start WSJT-X.
In WSJT-X under radio tab select Flex 6xxx and in the IP address field enter 127.0.0.1:5004
In N3FJP under settings/Rig Interface select Flex API and make sure mode set by Rig.
73 and speak to you tonight,
If N3FJP is set to Mode set by frequency the program (N3FJP) will set 40 and 80 meters as LSB.
N3FJP is not set to Mode and frequency. LSB problem is happening on all bands with WSJT-x,0
- 391 Community Topics
- 665 The Flea Market
- 166 SmartSDR+
- 446 SmartSDR for Mac
- 208 DAX
- 387 SmartSDR API
- 65 Aurora
- 304 FLEX-8000 Signature Series
- 978 Maestro
- 868 FLEX Series (Legacy) Radios
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 826 Peripherals & Station Integration
- 145 Amateur Radio Interests
