No sidetone for tuning after upgrade
Dave KC9EI
I upgraded my 6600M and have the Static IP issue like the others. I can work around that until the fix is released. BIT... another issue hasn't resolved itself and I suspect it may be operator caused. I cannot tune my radio via Smart SDR software. It switches but there is no sidetone audio for tuning. The WSJT tune works fine, CW keying is fine, RTTY is fine and SSB is fine. There is no transmit audio in DAX either when trying to tune via Smart SDR. WSJT works fine as do all the other modes.
Any thoughts or suggestions?
Alan. WA9WUD had the solution in a post I missed. I needed to set the sidetone to 600 in the CW mode and that fixed it. Thank you. Thank you Alan2
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
