PGXL fans in standby?
ShawnQuinn
Is there any chance of PGXL fans running in standby mode? Fans are set to standard.
SHawn
ve3xyy
Even in contest mode once the temp falls they go off. You could put it into broadcast mode.
why would you want that?
Peter
Hi Peter
I just wondered if it was safe to cover the amp in standby. Depending of the dust cover it could block air flow if the fans run. I just settled with a top fitted cotton dust cover with the top vent cut out exposed, does not cover sides or front.
Shawn
ve3xyy
The answer is yes, the fans do run really really quietly in standby.
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
