Frequency Display Cut Off
Bill
I have been unable in adjusting the Windows 10 monitor settings to keep from cutting off the frequency display on SSDR for Windows. See the image.
Suspect an easy fix.
Everything else works fine for SSDR 3.1.12, 32" NEC PA322UHD monitor set at 3840x2160 in Windows 10 Pro 64.
Help appreciated....
May have something to do with font sizes selected in Windows 10. Try going to System, Display, then scroll down to "Change the size of text, apps, other items", I've got mine at the recommended 100%
Do a Search on Font.
search in Flex download area for FONT and install it - they have used a non Win standard font - it's a easy job !
Chris
Problem solved!
Thank you so much!!!
73s
Bill
Had same issue, just found this thread....thanks Guys!
73, Charlie GI4FUE
- 390 Community Topics
- 659 The Flea Market
- 53 Aurora
- 971 Maestro
- 945 Genius Products
- 307 Shack Infrastructure
