How to monitor transmit audio when using FT8?
Pat Turcotte
Member ✭
Is there a way to use SmartSDR for Windows 10 (DAX?) to monitor transmit audio when using FT8 - without using a second receiver? Thanks for your input.
Pat, N4ENF
Pat, N4ENF
Turn on Show TX in waterfall in Radio Setup:
1) you may monitor the audio signal by turning on MON in the P/CW panel,
2) you may also monitor the TX audio by turning on Mic stream in the DAX control panel and if you have the 'DAX MIC stream' configured for 'Listen ' in the Windows Sound control panel.
3) as previously suggested, Visually in the PA and or WF displays.
AL, K0VM
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
