How to monitor transmit audio when using FT8?
Pat Turcotte
Pat Turcotte Member
edited April 2021 in SmartSDR for iOS
Is there a way to use SmartSDR for Windows 10 (DAX?) to monitor transmit audio when using FT8 - without using a second receiver? Thanks for your input.
Pat, N4ENF
  • Dave K5OZ
    Dave K5OZ Member ✭✭
    Turn on Show TX in waterfall in Radio Setup:
  • Al K0VM
    Al K0VM Member ✭✭✭
    1) you may monitor the audio signal by turning on MON in the P/CW panel,
    2) you may also monitor the TX audio by turning on Mic stream in the DAX control panel and if you have the 'DAX MIC stream' configured for 'Listen ' in the Windows Sound control panel.
    3) as previously suggested, Visually in the PA and or WF displays.
    AL, K0VM
