Antenna 1, Antenna 2 selection
w6gj
Member ✭
With an antenna connected to Ant 1 input and Ant 1, Ant 1 selected in the software No Rec, Tx tunes, with Ant 1, Ant 2 selected radio Receives ok, Tx will not tune. I would assume if Ant 1, and Ant 1 selected radio would be using Ant 1 for Receive and TX but apparently not. This is a used radio, new to me with no history. Now running v3.2.31 but same results with v2.6.2.
Best Answers
Some more details would help. Which radio? How many panadapters and slices? By tunes, is that using the tune button? Does the software indicate power output?
If ant 1 connected and ant1 selected, the radio should tx and rx on ant1 if properly configured. Sounds like the basic hardware is functioning if it will tx and rx. Maybe try a complete reset. This cures most of the glitches in my 6400.
Thank you will try the reset on the Flex 67000
There are two reference manuals, the software manual and the 6000 series hardware manual. The manuals are pretty well written, better than most ham manuals.
I have no documentation on this equipment. I have read that I should refer to the documentation on this radio. Have not found any documentation/manual on how to use this radio/software combination on the Flex website.
Thanks will try the reset.
W6gj1 -
There’s tons of useful documentation on the Flexradio website. Look under “support, “ then “documentation.”
- 319 Community Topics
- 576 The Flea Market
- 7.7K Software
- 6.2K SmartSDR for Windows
- 157 SmartSDR for Maestro and M models
- 386 SmartSDR for Mac
- 251 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 356 SmartSDR API
- 9K Radios and Accessories
- 125 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 848 Genius Products
- 437 Power Genius XL Amplifier
- 298 Tuner Genius XL
- 103 Antenna Genius
- 269 Shack Infrastructure
- 190 Networking
- 132 Contesting
- 699 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 923 Third-Party Software
