Transverter tx output level on Flex 1500?
mrthing2000
Member ✭
[{"insert":"What is the output max level of the xvrtr port on a Flex 1500?\nFlex 1500 manual says a level of 30 equates to 0dbm. It doesn't state a range of what level equates to what. So what then does 100 equate to in max output? Or any other levels.\nMy DEMI 222 xvrtr wants no more than 10db, so I am not sure what level is 10db on output.\nWhen I tried in PowerSDR I only saw output power levels in percentages and not mW or dbm.\nThanks!\n"}]
About +3dBm at 100% from the XVTR port.
