AGC Attack with NB Engaged
My neighbor has an electric fence along one edge of my property. It makes a lot of noise in my Flex 6500 using SmartSDR 2.4.10.
After seeing Tim's presentation on the QSO Today Hamfest about receiver adjustments, I have been using the Noise Blanker at a low setting (10 or less). That eliminates the noise.
I run a CW traffic net and when a very strong station calls in the first letter of the call is highly distorted. After that copy is fine. It's like the AGC is slow to attack for part of a second. Or it may be that the Noise Blanker is confused at first.
Is there a setting I can adjust to minimize the effect?
I had been using the Wideband Noise Blanker and it doesn't have this slow attack problem, but it also is not as effective at eliminating the noise.
I doubt it is the AGC that is causing it, but it is the initial "training" time that the NB does when it detects new signals. If changing the AGC to slow or fast makes no difference, then it is the NB that is responsible. I'd normally tell you to reduce the NB threshold, but you already have it very low to start with.
What is your AGC setting?
Hi Tim -
ACG-T is about 25 and AGC is MED.
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
