Audio device for CW monitor?
WR8F
Member ✭
Is there an audio device registered in Windows that carries the CW sidetone? I am trying to record with OBS and can't get the sidetone into the audio without just putting a mic by my speaker.
You should be able to click on PC Audio in the upper right corner of SmartSDR and then record the audio being sent to your PC speaker using Audacity.
PC Audio brings receiver audio to the PC and is useful for remote operation (even just to the next room...). CW side tone does not get routed to the PC because of latency through the Windows operating system. If you tried to send code using paddles or a key, it would be nearly impossible due to the delay through the PC. So the direct answer to the question is "No".
- 391 Community Topics
- 665 The Flea Market
- 167 SmartSDR+
- 446 SmartSDR for Mac
- 209 DAX
- 387 SmartSDR API
- 65 Aurora
- 307 FLEX-8000 Signature Series
- 978 Maestro
- 868 FLEX Series (Legacy) Radios
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 309 Shack Infrastructure
- 216 Networking
- 828 Peripherals & Station Integration
- 145 Amateur Radio Interests
