FLEX6700 frequency calibration problem
This hardware issue is being addressed via the HelpDesk by our technical support team.
Check to be sure that RIT is off or set to zero.
RIT is off or set to zero0
The FLEX6700 will only receive accurate reception for about 40 minutes after booting, otherwise the audio will be severely shifted, and the calibration frequency will also be invalid at this time. Why does the traditional machine such as icom7300, icom7800 and FT991A start to listen to the audio normally without tuning?0
About 40 minutes after the FLEX6700 is turned on, the audio will be normal to listen to, otherwise the audio will be severely shifted, and the calibration frequency at this time will also be invalid. Why do traditional machines (such as icom7300, icom7800 and FT991A) turn on and listen to audio normally?0
I don’t have this situation with the 6400. Stays on freq for hours, days. I suggest an help desk ticket.
Are you using a External or Internal GPS clock source?
At least on the 6700, and 6500 when using a external GPS source and if it looses the GPS signal for some reason it will revert back to the internal Clock oscillator.
If your not using a External GPS source then the issue is probably the on board Clock Oscillator and will need to Open a help desk ticket and send it to the for service when they give you a RMA number.
FLEX6700 turns on the power for 120 minutes to test as shown
Has been returned to the factory for repair. thank you all
- 379 Community Topics
- 631 The Flea Market
- 120 SmartSDR+
- 193 DAX
- 38 Aurora
- 947 Maestro
- 924 Genius Products
