Error message
David Gardner
Received error message on my 6700 when transmitting and with Maestro also running. The 6700 shut down with red light blinking and with this message: PSL1V5 1.38. Anyone know what this indicates?
This has nothing to do with the external power supply. This indicates that the internal 1.5v voltage regulator could not supply sufficient voltage. If this happens more than once or twice, the radio will need to be serviced to repair it
Sounds like the 1.5 volt supply in the radio dropped down to 1.38 volts. Double check the voltage of your power supply and check the connections, especially the power pole contacts.
Use a program such as FRStack to check your radio voltage while transmitting a 100 watt carrier to see if you have a significant voltage drop.
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
