Mixing Mac and PC versions of SmartSDR?
Probably dumb questions, but I've searched the community and can't find an answer:
If I'm using Windows 10 on my home PC, but have a Mac laptop, can I use SmartSDR on the two machines interchangeably? Use the PC when at home but the Mac remote? And if so, do I need to buy a separate license for the Mac, or are both versions covered under the v3 license on the radio?
    Answer ✓
    Hi Mark, yes you can use them interchangably. You can even use them simultaneously using MultiFlex since you are on V 3.
  • To my knowledge they are separate programs. The only difference is that the Mac version is a one time only fee regardless of the radio's version software.
    Gordon, ve7on
  • John KB4DU
    John KB4DU Member ✭✭✭✭
    Mark,
    l use SmartSDR on a pc, and iossdr on an iPad simultaneously. The radio doesn’t care which two (on a 6400) are connected.
