Spot Remove All Command
Alan
Alan Member ✭✭✭✭
edited January 2021 in SmartSDR API
Per the Wiki, the command to remove a spot is:
C[D]<seq_number>|spot remove <spot_index>
Where <spot_index> is the specific spot you want to remove.
Question:   What is the commnad to remove all spots?
Alan
WA9WUD
Best Answers
  • Mark_W3II
    Mark_W3II Member ✭✭✭
    Answer ✓
    If you have not already found the answer "spot clear" should work.
  • Mark_W3II
    Answer ✓
    Done.
    Just released FRStack 3.1.26.55
    Added Radio Memory REST API, Radio SPOTS REST API, Hot keys for CWSPEEDUP1 CWSPEEDDOWN1 and a new feature where Slice B tracks Slice A frequency w/ rev direction feature. The last feature can be used to work satellites.
    FRStackWebApi releases will follow shortly.
    Hi Alan, I haven't tried this yet, but it seems like you could do a for loop (or whatever the Node Red equivalent is). Increment spot_index from 0 to 999 in a remove command. Just ignore the messages about invalid spot_index. I also wonder if a spot_index of ALL would work.
    Len, KD0RC
  • Alan
    Alan Member ✭✭✭✭
    Thanks, Mark. I will give that a try. Perhaps a candidate for a REST command in the next update?
    Alan
  • K3CDY
    K3CDY Member ✭✭✭
    edited April 2025
    I am working on a simple macOS app to clear all spots (since Marcus's app doesn't do it), and using WireShark with Windows SmartSDR in a VM, I discovered that the command to clear ALL spots is:
    C[D]<seq_number>|spot clear
    Easy-peasy.
    I've added an "Issue" to the Flex Wiki to have this command added.
