powering on 6400
Best Answers
Hi Lee, There are some relays that make noise when powering up, is that what you are hearing?
Len, KD0RC
Lee, Check to determine if your speaker is on, I get that clunk when I shut down with the external speaker on.
W2JV
Peter
With my powered speakers on a 6600M, I will get some audio noise when powering up or down (more when powering down than up). If the speakers are turned down, all I hear is the clicking of a bunch of relays.
The 3000 you hear a single relay click. 6400 is a real heavy tunk sound. I think I can hear a relay click in there as well. Same power supply Astron RM-35A. This is powering up from a total shutdown. I **** all power when done with the radio. Powering off ever thing first.0
Speaker was the source. 3000 did not do that. Thank you: Lee0
Disheartening. Audio amps have had anti-thump during turn on for decades.
I hear no such “real heavy tunk sound” when powering up my 6600M.
I hear it in my 6400, but I think it is due to keeping my amplified speakers all the way up. If I turn down the speakers and correspondingly turn up the Flex volume, I don't notice the noise. Since it is just a startup or shutdown thing, I don't consider it a problem and have gone back to keeping the speakers at full volume.
Len, KD0RC
The 3000 just made a quite relay click. With the 6400 I am using different speakers so that may make a difference. It still makes more noise than the 3000 when powering on. I usually wear headphones so will unplug the wart for the speakers until I need the speakers. Just being careful with the 6400 and do not want to **** things up accidentally. Thank you for the help.
VE6MKM0
- 379 Community Topics
- 636 The Flea Market
- 140 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 271 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
- 793 Peripherals & Station Integration
