Antenna switching 2 each 4 way switch boxes
I'm using now A Denkovi USB relay board with eight channels connected to my 6600 USB Bit cable to auto switch one 4 way antenna relay box . This has been working great for the past few years .
I'm wanting to add a second 4 way antenna relay box to were the first box in the shack will send RF to the second box on the tower . I'm posting a picture to help explain . In the picture I show a wire from the control board tower relay to the tower port in the shack .. I know that's not correct . What I'm thinking may work is to add a second wire from the control board 160, 60 and 10-20 to the Tower port in the shack .
I think I need 3 steering diodes but I'm not sure where to put them and in what direction ?
The picture will most likely make more sense then me
Am I on the right track ? is their a better way ?
Thanks Ed N5DG
After a little studying , I have it figured out. Solved as they say
Ed N5DG
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
