Front panel IP/DHCP flashing
I haven't used my amp in some time. The last time I had it on was to update to the newest firmware a few weeks back. I turned on the amp tonight and on the display on the front of the amp had a message flashing saying "DHCP-IDLE" where the amp normally displays the IP address. If I open up the PGXL utility software on my computer, the display is fine and shows the IP address. The amp seems to work OK but that flashing message is annoying me. Any ideas on a fix?
Burch
K4QXX
Just got my PGXL a few days ago, jan 2021, and have a similar problem (?). I use a static IP. The utility SW has it show up correctly but the front panel on the amp flashes similarly right after "IP:"
Mine flashes [STATIC - IDLE] whether or not I am in operate or standby or transmitting.
FLEX - ?????
I submitted a ticket for this condition. Tim and the group have it identified as a software issue and have assigned it issue #395 so it is list to be addressed.
If I use a static IP, I get the fishing STATIC - IDLE as well. Mine has been doing it for several months. I am sorry that you are also having the issue but at least I know I'm not the only one. Hopefully just a software issue.
- 389 Community Topics
- 53 Aurora
- 970 Maestro
- 944 Genius Products
- 307 Shack Infrastructure
