Flexradio 1500 interfaced with MX-P50M
Hope this makes sense but can not found anything on the net to answer my questions.
The amp keying is performed by a solid state device, rated at 50 volts at 50 milliamperes, should key most modern amps, BUT its a good ideal to use an external keying relay to better isolate the radio from any noise or transients that might come back down the amp keying line. I personally always had a external relay and have not had any keying issues with 5000, 3000 or 1500.
Dudley, WA5QPZ
Thank you very much Dudley for answering my question. I really appreciate it. I will look into the external relay.0
I have ordered an MX-P50M waiting patiently for it to find its way to the UK from China! In the meantime I have been researching PTT switching options and came across the solution below that uses a widely available MOSFET and a couple of resistors. I have built it and plan to use it with my Flex1500 and MX-P50M. Thought I would share it in case its of any use to anyone!
I really don’t think the Little amp your looking at will key with much more current then the Keying circuit you are looking at.
If the amp is built for a modern day radio like the FT817 then it will work with the Flex1500, KX3 etc radios with no problems.
The FT1500 uses a FET on the key port if I remember right which is rated by FLEX in the owners manual to handle 250MA and 30 Volts which is probably FAR more then the little MX-P50M AMP needs to key your looking at.
Agreed, although I built the cable as above in my previous post and its working perfectly I guess although not really necessary it cant do any harm. Only seem to to be able to get about 35 watts out of it though, my 1500 doesn't seem to generate 5 watts at full drive, I can get about 4 watts on full drive with FM.. Not sure why!
excellent glad it worked for you
- 383 Community Topics
- 638 The Flea Market
- 145 SmartSDR+
- 434 SmartSDR for Mac
- 273 SmartSDR for iOS
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
