how to set the agc-t
Lee
how to set agc-t
Hi Lee, here are some links that might help. A good starting point that I use is to subtract 95 from the level of the noise showing on the right hand side pf the panadapter and set the AGC-T to that. So if you noise is around -125, set your AGC-T to 30 as a starting point. You may need to increase your volume quite a bit to compensate. The good news is that the volume is now amplifying more signal than noise. I found that the AGC-T needs to be set much lower than I expected.
https://www.flexradio.com/documentation/using-the-agct-and-af-gain-controls/
Len, KD0RC
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
