error codes on 6700
kk4x
Has any one experience the following error codes on there FLEX 6700:
PSL 3V3 295 AND PSH 5V3 574. Any input appreciated,
also while doing a Hard Reset, my 6700 Times Out.
I put in a help ticket already with more issues too.
thanks for any input.
Anytime you experience a hardware issue and receive these types of error codes, you should open a HelpDesk support ticket.
The radio has multiple voltage rails each regulated by a dedicated voltage regulator. The errors above indicate that the 3.3V rail is in an under-voltage condition and the 5.3V rail is in an over-voltage condition.
Why this is happening needs to be investigated, hence the request to open a HelpDesk ticket. Thanks for doing so.0 -
[{"insert":"why are there not any service manuals out for the flex 6000 series? \n"}]0
Few user serviceable parts. Almost everything is done by software.
- 379 Community Topics
- 636 The Flea Market
- 140 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 271 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
- 793 Peripherals & Station Integration
