SmartLink quit
Smartlink was working last night. Local connections aren't an issue. 6400M running v3.1.12. Nothing has changed in my network. Fixed IP manual port forwarding. uPnp is shut off. All IP addresses look fine. I have unregistered and re-registered several times. Nothing in the firewall is blocking it. Anti-virus isn't blocking it either.
The only thing I saw change was SmartSDR for iOS updated. The iPad works fine as long as I am connecting locally, but smartlink is toast.
What am I missing?
Ed KA9EES
The voice of Fithian IL
What version of SmartSDR are you using? On IOS after14, some apps require being given to the network.
v3.1.12 it's been working fine under iOS14.1 till now. I don't understand what you mean by "being given to the network". iOS didn't update. SSDR for iOS updated. Hmm... Maybe I should ask Markus about it. The thing is when I try the test button on the front of the rig, I get a red light. I don't think it's an SSDR for iOS problem.
Ed
Auto corrupt caught me again. Should be given access to the network. I’m on IOS 14.0.1 and app version 3.9.8
which is working.
The app works fine. SmartLink doesn’t
Can you check remote access from a pc running SmartSDR for Windows? That will determine if it is an IOS or radio issue.
Try rebooting the radio and check if SmartLink is set up correctly. When in SmartLink setup expand the Network setting and click the test button. If it does no go green then you have an issue with port forwarding.
I setup my Windows 10 laptop using my cellphone as an hotspot. No joy via smartlink. Then via the local wireless network. Works just fine.
Ed KA9EES
All is right with the world now. Mika VA3MW Ken NM9P helped me solve the problem.
Ed KA9EES
Mike and Ken are great!
(as well as the whole Flex team)
All,
Just a observation. I have the same problem today connecting from work .. This morning was working remotely before clocking in, worked just fine. Then logged off till lunch time. Noon came tried to log in with windows 10, latest version SDR software and 6600M. So i took to the community to find a answer and here it is but the answer truly is not published to see the solution. the answer posted is "Mike VA3MW Ken NM9P helped me solve the problem"
Checked my home router remotely and radio via teamviewer all is good . No remoter connectivity via Smartlink. Tried IPhone, Ipad and windows 10 machine.
So folks now what.... HI Hi
I ended up having to enable UPnP. As I had been using a fixed IP. It just stopped working. I hadn’t made any changes. Honestly I don’t know what happened.
Ed KA9EES
Ed,
Thanks for the reply.
I am really baffled for sure on my end. In the last 24 hours i got it working but did find the IP of the radio changed some how and i don't understand that. Its above my pay grade. I have a a ATT router and live in the boonies so i have not a lot of choices. It wont even let me use it as a bridge. Another ham who is very much a guru when when it comes to this stuff was baffelled as well. We changed the port forwarding to the new radio Ip and still didnt pass the green light test. But here is the kicker, I believe we chased our tails for 2 hours figuring it wasnt working because we could not get the green light, this morning i tried from work and all is good but no green pass test light still red. So i hope somebody from FR can answer that one. Been on 3 different bands this morning from work and my 2 meter transverterand it working. I dont like these mysteries but right now i am happy. One could waste hours trying to get the green light when in fact you set everything up right.
73 W9GD
Gary,
Do a Google search on the model of your AT&T router and how to do a DHCP reservation and add a reservation for the radio. What that does is the router will see the MAC address of the radio and always assign the same IP address to the radio.
This is better than using a static IP address. If you use a static IP and you ever move the radio to a different network which has a different subnet , you will not be able to see the radio on the network. Also if you ever want to connect the PC direct to the radio it also would not work.
I have DHCP reservations for my radio, amp, 4O3A antenna switch, PC, and Node Red Raspberry Pi. That way I know the equipment always gets assigned the same IP.
73 Dave wo2x
Dave,
Thats a great tip i will look into that. Thank you very much. It is appreciated.
73 W9GD
- 384 Community Topics
- 643 The Flea Market
- 149 SmartSDR+
- 262 SmartSDR CAT
- 961 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
- 142 Amateur Radio Interests
