Battery for Maestro
Here’s what I bought recommend by Jason at hamradio 2.0 Mogix External Power Bank Charger with 2 Fast USB Ports Compact 10400mAh #Voted Best Travel Phone Accessories TSA Compliant Carry-on1
Thanks. Curious - does this both power the maestro as well as charge thru the USB-A, or were any adapters needed? None of the (2) power banks I have will charge via the USB-A. Thanks again, bob0
There is a micro USB port to charge the Mogix pack. Note - it will take about 6 hours to fully charge the pack.
Promotion on amazon. Buy the battery and get a $14 electronics case free - pretty nice looking case. I just placed my order. @awinger thanks for the recommendation
https://www.amazon.com/Mogix-External-Battery-Charger-10400mAh/dp/B00MFVNLXK
I'm confused about connectivity - maybe this will make more sense once I have the Maestro. None of the batteries I've looked at will recharge thru the USB-A port. The Maestro has only a USB-A plug. Does that mean the battery will not recharge while in the unit and must be removed for charging? The manual is silent on this point. Thanks, Bob0
Correct. Due to the different batteries available and potential for fire hazard (hover boards?) the battery packs need to be charged outside the Maestro.
Gotchya! Wish the manual had stated that. -Bob0
I just got my battery and free case - works great, thanks @awinger
One caveat. Be sure and run the Maestro from an external power source from time to time. The internal battery will not charge from from a portable battery. Even in the “B” version.
Ed KA9EES
That's good to know. Thanks, Bob0
- 317 Community Topics
- 575 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 365 SmartSDR for Mac
- 251 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 356 SmartSDR API
- 9K Radios and Accessories
- 122 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 847 Genius Products
- 298 Tuner Genius XL
- 103 Antenna Genius
- 268 Shack Infrastructure
- 189 Networking
- 132 Contesting
- 696 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 921 Third-Party Software
