Maestro Smart Control Add Mic/Headphone/PTT/Paddle Support
Asher - K0AU
Member ✭✭✭
in New Ideas
When I run a Maestro in its basic mode I connect Mic/Headphone/Paddle to the Maestro.
Wouldn't it be great if the same connectivity worked with Maestro in SmartControl mode? Use SSDR on your computer with remote audio, PTT and paddle supported through the Maestro?
Even better if CAT Winkey sidetone is carried back on the Maestro Smart Control channel for those of us using N1MM+ for contesting.
Ideally this feature would work with LAN or SmartLink connection.
Yes indeed, it is very disturbing that Flex came up with the fantastic idea of allowing Maestro to control a PC SDR and not enable the mic and PTT to also function! I have asked several times as to when this functionality could be enabled and never got a response!0
+1
- 390 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 59 Aurora
- 974 Maestro
- 947 Genius Products
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
