Replacement Fan for Flex 5000a
jerryco
Member ✭
The fan on my Flex 5000a is making noise. It is noisier for the first two minutes after startup and then gets a little bit quieter but I think it may be time to think about a replacement.
Does anyone know where I can obtain a replacement fan for a 5000a?
Thank you - Jerry
Thank you - Jerry
Best Answers
Although I don't think Flex directly supports the 5000 any more, it might be worth a call to them (or submit a Help Ticket) to see if they could at least point you in the right direction (i.e. specs for the replacement).
5 -
If it were me I'd look at the fan to see the make and model as a starting point. Then see if the manufacturer still make the same model or find an equivalent model from the same or different manufacturer.
5
Thank you very much Don and Geoff! I will try your suggestions. - Jerry0
This should be an ok fit for the 5000a fan.
AeroCool Shark 140mm Blue Edition 140mm Case cooler - Newegg.com
The fan will plug right in, you just need to elongate the holes for mounting.
- 328 Community Topics
- 594 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 397 SmartSDR for Mac
- 260 SmartSDR for iOS
- 247 SmartSDR CAT
- 179 DAX
- 369 SmartSDR API
- 9.1K Radios and Accessories
- 15 Aurora
- 162 FLEX-8000 Signature Series
- 909 Maestro
- 51 FlexControl
- 873 Genius Products
- 312 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 135 Contesting
- 725 Peripherals & Station Integration
- 136 Amateur Radio Interests
- 945 Third-Party Software
